NI TestStand
How to find steps that use a given local variable?
I have a variable in my TestStand sequence called Locals.x, and I want to find all of steps in the sequence that refer to it. I thought I might be able to right-click the variable in the "variables" pane, and use something like "find steps using this variable."
So far, the only way that works is to rename the variable (e.g. to Locals.x_), and then click the Analyze button to reveal the errors that result. This is a clumsy method, though.
Any other ideas?
(4,056 Views)
Accepted by Artybear
What's wrong with using the TestStand Find/Replace tool?  Just hit Ctrl-f and type Locals.x in there.  Then click Find/Replace.  You will get a list of all the places that it's used.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,054 Views)
Thanks. Not sure why I didn't think of that in the first place. 🙂
(4,051 Views)
