NI TestStand
How to fix missing panes
Every once in a while, I run into this problem where I can't see the pane I'm looking for, especially if TestStand is not full-screened. I keep forgetting the IDE has a weird layout bug.
Hopefully this animation helps people.
TestStand_FixMissingPanes
(513 Views)
We found re-loading the configuration to be a workaround
(478 Views)
Yes, I verified that also fixes the pane.
Thanks for the tip!
(469 Views)
