NI TestStand
TS2024 Reusing sequence files across TestStand versions
In the 2024 release announcement there was this section:
Starting this release, sequence files can be used across versions of TestStand without re-saving. This would be supported across versions where there aren’t breaking changes, this is indicated by change in the engine version number (which can be found in Help >> About TestStand)
Is there any further explanation/documentation of this feature? I downloaded 2024 and it seems to behave exactly like the previous versions.
  • After opening a sequence file of an older version, it will default to saving it in the latest version (shows the '+' next to the filename in the tab).
  • Trying to open a new file in an older version gives the error that the file version is too new.
(637 Views)
TestStand has introduced the concept of Engine version. You can view it in Help >> About TestStand.
In TestStand 2024, we have retained the same Engine version as TestStand 2023. So, any sequence file saved in TestStand 2023 can be opened in TestStand 2024 without '+' or '*' dirty dot. If you are using sequence file saved in other previous versions, you will get '+' dirty dot.
In other words, once you save the sequence file in a specific Engine version, irrespective of version of TestStand, as long as Engine version is same, you can open the sequence file without any dirty dot.
Note: Going forward, TestStand intends to keep Engine version same as much as possible.
-Shashidhar
(613 Views)
I didn't realize Engine version and TestStand version are separate now. And the compatibility only exists on the same Engine. This makes more sense now.
Thanks!
(604 Views)
