NI TestStand
How to generate a global synchronise object?
Means a synchronise object(For example a lock) is visible by different sequence file? Is this possible? More less global variable.
(2,649 Views)
If you put an * at the beginning of the name for the synchronized object it will work.
For example:  "*MyLock"
From this link: https://zone.ni.com/reference/en-XX/help/370052W-01/tsref/infotopics/sync_objects_name/
"By default, you can access a Synchronization object only from the operating system process in which you create the object. However, you can make a Synchronization object accessible from other processes, such as multiple instances of a user interface, by using an asterisk (*) as the first character in the name."
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,623 Views)
Thanks for the information.
From your comment , I realized the the default  Synchronization object maybe good enough for my case.
Means:
 "MyLock" (Without '*'),can be visible between process module sequence file and the client sequence file.
  I think they are in one process.
  Is this correct?
Best Regards
Mark
(2,617 Views)
