NI TestStand
What is the best way to change STOP_ON_FAIL?
Normally production test sequencer has this configuration : STOP_ON_FAIL.
In normal production if a test step fail, test sequencer will stop, skip the remaining test steps and show up failure. This can save test time.
But in some cases (for example to deeply investigate the failure part),we need the sequencer do NOT stop when it fail, until go through all test steps, This is sometimes helpful for failure analysis.
What is the best way to achieve this in TestStand?
(2,965 Views)
Accepted by topic author MarkZhou
Do you have the station global "Immediately Goto Cleanup on Sequence Failure" set to achieve this behavior?
If so you can programmatically set it to false so that the program continues after a failed step. (Don't forget to enable it again)
(2,943 Views)
Configure----> Station Options------->Execution--->uncheck (Immediately Goto Cleanup on Sequence Failure)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,931 Views)
Hello Palanivel,
I tried,It work.
Thanks.
Mark Zhou
(2,923 Views)
Great!
Thanks.
(2,920 Views)
