NI TestStand
How to generate automatically sequence files
I have to generate automatically sequence files  (using C# in dotnet) for TestStand without having to manually edit it through the editor.
The motivation for that is hundreds of existing scripts that we wish to move to TestStand. the idea is that we created custom step using .NET dlls, we already customized TestStand to use them (according the help files) and this works. now the next step is that we want to create a sequence file containing many of this custom steps, each with different values. we would like to develop a utility that will automatically do that.
But  meantime I didn't find such option, to do that in C#. Please help me to find a solution for that problem.
Message Edited by ramiyam on 09-19-2006 01:37 AM
Message 1 of 13
(7,918 Views)
Hi ramiyam,
It is possible to generate a sequence files programmatically.
The best place to start would be to look at our sequence builder tool shipping example. Locate this example at <TestStand>\Examples\SequenceBuilderTool. This example acts as a tool for programmatically creating and executing new test sequences. The tool clones prewritten and configured test steps (such as your custom steps) located in a template sequence to create a new test.  The examples are for C and LabVIEW but you should be able to use the equivalent API calls in C# for those in the LabVIEW example.  Let me know if this helps.
Have a great day,
Ecleamus Ricks, Jr.
Message Edited by Ecleamus R on 09-19-2006 06:33 PM
Message 2 of 13
(7,899 Views)
but there is still problem.
Now I have the following code that builds and saves a sequence file with step:
public void CreateSquence(Engine engine)
SequenceFile sequenceFile = engine.NewSequenceFile();
Sequence sequence = engine.NewSequence();
sequenceFile.InsertSequence(sequence);
Sequence mainSequence = sequenceFile.GetSequenceByName("MainSequence");
Step step = engine.NewStep("Sequence Adapter", "Label");
step.Name =
"Bla bla bla";
mainSequence.InsertStep(step, 0,
StepGroups.StepGroup_Main);
sequenceFile.Save(
@"C:\newSwquence.seq");
When I open the generated sequence its looks properly, with proper icons on each step and also if there is some "Edit" before the test execution option its runs properly.
But when i try to execute the built sequence i have the followin message:
|  Model enter point "Single passs" could not been executed                                        |
|  Error loading step 'blalbabla' on sequence 'MainSeques' in file 'z1.seq'                        |
|  Attempted to load a module for a step whose module has not yet been specified.        |
|  Error code: -17601        |
|  Source: 'TSAPI'        |
Please show me the way to solve the problem, I have spent a lot of time and have no solution.
Thank you,
Rami
Message 3 of 13
(7,881 Views)
Rami,
You are creating a new label step using the sequence call  adapter.
You are getting the error because for sequence call steps you have to specify the module before executing it.
You would get the same error if you insert a sequence call step in teststand and try to execute the sequence without specifying the module.
I assume that in your example you just want to insert a Label step. Pass an empty string as the adapter name in order to use the adapter designated by the step type or, if the step ha no designated adapter, to use the default adapter.
Step step = engine.NewStep("", "Label");
For more information I would recommend you to check the TestStand Help.
Hope it helps.
Antonio Lie.
Message 4 of 13
(7,870 Views)
Thank you Antonio,
it was very helpful.
Rami.
Message 5 of 13
(7,825 Views)
I tried that also in C#, now also in CVI. But i can't get the "InsertStep" command to work. I do it in the same way as described here. It returns always an error -17337: Step type 'Label' not found in type list. I tried to leave the adapterKeyNameVal empty and the "None Adapter". Any ideas? Maybe i forgot something to include?
Message 6 of 13
(7,281 Views)
Hi Thomas,
Attached is a code snippet to do what you desire. Perhaps there was a minor typo.
Attempt to run this piece of code, and let us know if you continue to have the same problem.
Note for a listing of Adapter Names and Step Types, please reference to the AdapterKeyNames and StepTypes, respectively, in the TestStand Help.
 CAObjHandle TSEngine;
 CAObjHandle SequenceFile;
 CAObjHandle MainSequence;
 CAObjHandle Step;
 TS_NewEngine ("", &TSEngine);
 TS_EngineNewSeqFile (TSEngine, NULL, &SequenceFile);
 TS_SeqFileGetSequenceByName (SequenceFile, NULL, "MainSequence", &MainSequence);
 TS_EngineNewStep (TSEngine, NULL, "None Adapter", "Action", &Step);
 TS_StepSetName(Step,NULL,"Bla bla bla" ) ;
 TS_SequenceInsertStep(MainSequence,NULL,Step,0,TS_StepGroup_Main) ;
 TS_SeqFileSave(SequenceFile,NULL,"C:\\newSequence.seq" );
 //Release
 TS_EngineReleaseSeqFileEx (TSEngine, NULL, SequenceFile, 0, NULL);
Nestor
Message 7 of 13
(7,242 Views)
Hi Ramiyam,
thanks for your help. But that was the way i tried already and it doesn't work. Please see the screenshot. The TS_EngineNewStep() function returns an error "Step type 'Action' not found.
Thomas
Message 8 of 13
(7,231 Views)
You need to load the type palette files first before the Label step will come into memory.
Use the Engine.LoadTypePaletteFilesEx method to do this.
http://zone.ni.com/reference/en-XX/help/370052G-01/tsapiref/reftopics/engine_loadtypepalettefilesex_...
Allen P.
NI
Message Edited by AllenP on 09-25-2008 08:39 AM
Message 9 of 13
(7,224 Views)
Hi Allen,
yeah, now it works. Thanks a lot!
Thomas
Message 10 of 13
(7,215 Views)
