NI TestStand
How to get Failure chain string in PostBatch?
I'd like to show the operator the reason UUT has failed. I'm using a custom VI in the postbatch to show the results.
I can get the status and several other parameters. But I can't see anything related to the failed step when I stop the sequence at a breakpoint and browse the Variables.
Parameters.ModelData.TestSockets[0].UUT.CriticalFailureStack is empty although the TestSocket has failed at one step.
(2,049 Views)
Have you had a look at this forum post?
Get Data of the Failed Step that Caused Sequence Failure
MBengths
(2,023 Views)
