NI TestStand
Unable to open Teststand 2016 in win 10
Hello All,
I am using win 10 PC and installed Test stand 2016 successfully. but when i tried to open the sequence editor i got error saying "Test Stand 2016 (16.0.0.185) must be the active version of test stand to use the sequence editor". i have installed Test stand 2014 also in my PC and tried. getting the same error.
Anyone knows how to resolve this issue?
Kalpana
(2,739 Views)
Run the version selector and choose 2016 from the Installed TestStand versions: dropdown.  Then click Make Active.  The version selector activates all of the active X components for that version of TestStand so it will work.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,717 Views)
You also have to restart the PC after installation. Version Selector should run automatically the first time you restart after installation.
https://www.linkedin.com/in/trentweaver
(2,714 Views)
Thanks for the response.
I have tried running version selector but it is throwing error.
attached error snap for reference. I have restated my PC and tried all these.
kalpana
(2,706 Views)
Have you seen this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OLFSA2
Hope it helps,
jigg
CTA, CLA
testeract.com
(2,695 Views)
