How to get milisecond out from time function?
Hi All
I am using time function to get the current time of the step. I am getting only in hh:mm:ss format and unable to get miliseconds. However miliseconds are getting updated in local.I am not able to get in the final OP.
Is there anyway to get the miliseconds from time function ?
(5,092 Views)
Not sure what you are after exactly, but the following should return milliseconds in Locals.ms.
Locals.timeString=Time(False,Locals.hours,Locals.min,Locals.sec,Locals.ms)
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(5,085 Views)
Thanks for reply.
I am doing the same thing. but in the final string(here Timestring) I am only getting values till seconds.
However if i think the ms local value it is getting updated with miliseconds value.
But in the timestring I am not able to get the milisecond value.
(5,078 Views)
Accepted by LV_user1
I dont think you can do that with the time function directly.
You will just have to concatenate the ms value!
Locals.timeString=Time(False,Locals.hours,Locals.min,Locals.sec,Locals.ms),Locals.timeString+="."+Str(Locals.ms)
(5,071 Views)
Thanks ...it worked  Smiley Happy
(5,056 Views)
