How to get the list of step name of the TestStand Sequence ?
I have a sequence file of subsequence and steps. How can I get a list of the name of the sub-sequence(and steps in it) and other steps in text or word format without running the sequence?
I tried "save as" save the sequence file in to a xml file and parse it but no luck.
Thank you so much!
Message 1 of 10
(1,279 Views)
might help a bit
Message 2 of 10
(1,266 Views)
Even I uncheck all of the options, it still has a lot more than just the step names. Thank you for your help!
Message 3 of 10
(1,238 Views)
If you are willing to step into the API, this would be quite easy
Message 4 of 10
(1,226 Views)
Do you mean step in the sequence?  Please give a little bit more detail or screen shot. Thank you so much!
Message 5 of 10
(1,210 Views)
Accepted by BigDrum
Not sure if all you want is the list of step names as text, but you can just select steps in the sequence editor, hit <Ctrl-C> and then paste in a text editor.
Scott Richardson
https://testeract.com
Message 6 of 10
(1,206 Views)
Yes, that is kind of what I need. After paste to word, I have to adjust the indentation manually though. That is a small task not worth time to write a script.
Thank you!
Message 7 of 10
(1,199 Views)
I meant If you wann use the API....
Yet seems you got a solution
Message 8 of 10
(1,188 Views)
Yes, step in the sequence.
From this seq
I want
but after copy paste, I got this which need to manually fix the indentation. It is ok if the sequence is not long and not many layers of indentation, but it is a pain if the sequence is complex.
Message 9 of 10
(1,184 Views)
If the build in possiblities are not sufficient for you, you have to implement your own taylored solution using the TestStand API
Message 10 of 10
(1,170 Views)
