How to get the name of a previous test?
The top level of my sequence is a list of subsequences, each one being a  sub-test.
While inside one particular sub-test I would like to know the name of the sub-test which was executed before the one I'm in at the moment.   Obviously this is relevant only when I run selected sub-tests.
example:
        MyTest.seq
             sub-test1
             sub-test2
             sub-test3
I'm inside sub-test3 (in the setup or main sequence), and would like to know the name of the sub-test which was executed before sub-test3.  It is possible that no sub-test ran before sub-test3.
RK
Message 1 of 8
(5,204 Views)
Hi Rafi,
Try RunState.PreviousStep.Name()
Do a check if PreviousStep exists by using PropertyObject("", 0) with RunState.PreviousStep as the reference.
Hope this helps
Regards
Ray
Regards
Ray Farmer
Message 2 of 8
(5,196 Views)
Hi Rafi,
Just in case you are using an earlier version of TestStand than 4.0, you might consider using the NameOf() function since you wouldn't be able to directly access the TestStand API through expressions.  Here are a couple articles to look into.
Getting the Name of Any TestStand Property Programmatically in TestStand
Storing Step Names of a Sequence in a Local Variable
Let me know whether the suggestions above point you to a solution.
Rod T.
Message 3 of 8
(5,176 Views)
Thanks Ray,
Previous step does not work because I'm verifying it within a sub-sequence (see my example).  Previous step, then, will give the name of the stop executed previously to the present step.  THIS IS NOT WHAT I WANT.  I'm looking to find out the name of the sub-sequence that ran before the sequence i'm in.
example
   MainSequence
          sub-seq-1
          sub-seq-2
          sub-seq-3
I'm inside sub-seq-3.  I run a partial test and therfore I would like to know whether sub-seq-2 ran previously or not.
(I can work it out, using a local variable but I'm interested to learn how to find it using the RunState variables.)
Message 4 of 8
(5,121 Views)
Hi Rod,
Thanks for the links and especially to the one with the example.  Indeed some example!!  I ran it and was overwhelmed by that one step that creates a whole array of steps name.   Very nice.  I will take me some time to digest it...but I got the idea.
Besides this, I'm still looking for a simple way to find just the name of the sub-seq that ran before the present sub-seq (please see my answere to Ray).
Rafi
Message 5 of 8
(5,118 Views)
Hi Rafi,
Sorry about that. What you might try is RunState.Caller.RunState.PreviousStep.
RunState.Caller gets you back to the Caller Sequence and therefore you should be able to get the Previous step. I haven't tried it as I dont have TestStand to hand but it should work.
Regards
Ray
Regards
Ray Farmer
Message 6 of 8
(5,116 Views)
Hi Rafi,
Just to acknowledge Ray's answer
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 7 of 8
(5,104 Views)
Accepted by Rafi2003
Thanks Ray and Rod,
It is working now!  However, I ended up using the index rather than the name  (RunState.Caller.RunState.StepIndex  and   ... PreveiousStepIndex.  By using the indexes I can tell whether the previous test has been executed and whether the running test is the first step.
Thanks again
Rafi
Message 8 of 8
(5,077 Views)
