How to get the start date and time of a socket when using batch model
Until now, i was using SequencialModel and #NoValidation(RunState.Main.RunState.Caller.Locals.StartDate.ShortText) to get the string date and time, for report and so on.
Now, i need to use BatchModel, and it looks like Locals.StartDate is no longer there.
Doesn anybody know another variable that contain this information?
Thank you in advance!
(599 Views)
I found in the model, the place where the date and time are saved, but i don´t understand how to access these variables from the outside
I need this time, because it is used in some subsequences to always find the path to save data on disk and so on.
This is my structure
I would like to avoid to get time stamps in the Main sequence, because there are many main sequences which i would need to change.
Thanks!
(586 Views)
Accepted by Marian_G
When using Batch, this data is stored in RunState.Root.Parameters.TestSocket.StartDate.ShortText.
Please note it is better to use RunState.Root to access the Process Model that is running the test.
In Sequential it is: RunState.Root.Locals.StartDate.ShortText
No matter how big your call stack is, Root will be the process model entry point SequenceContext that contains the StartDate.
(556 Views)
Thanks a lot for the solution and for your fast response!
It worked, with a small change: RunState.Root.Parameters.TestSocket.StartDate.Text instead of RunState.Root.Parameters.TestSocket.StartDate.ShortText.
Marian
(541 Views)
Just a correction to my previous post:
RunState.Root.Parameters.TestSocket.StartDate.ShortText works.
(537 Views)
