03-08-2007 04:10 AM
05-15-2007 09:06 AM
05-16-2007 02:32 AM - edited 05-16-2007 02:32 AM
Thanks, Karsten
I have to admit that I was unaware that TestStand 4.0 is available. I will have a look at the list of new features. I hope it has some better analysis tools. For example, it often takes me a lot of time to discover that someone has modified the parameterlist of a sequence modifying all calls to that sequence. This can lead to strange behaviour. When opening a sequence call these kind of errors are immediately visible because they are marked red. Would it not be great if I would not have to open each sequence call due to a 'report errors' option in the menu that lists all items that would be marked red when opened? 🙂
Oops, I got carried away a bit there.
Greetz, Ovide
Message Edited by Ovide on 05-16-2007 02:33 AM
05-16-2007 03:51 AM
You are still going to get that problem with TS 4.0![]()
Regards
Ray Farmer
