NI TestStand
How to import MATLAB .m file into VeriStand sequence?
Hi all, I have to use the .m file parameters in my sequence. How to import the MATLAB .m file into sequence? If we can't import directly, then is there any other way to import it?
(764 Views)
Your question is best to be posted on the VeriStand board
I believe you are referring to the VeriStand Real-Time Sequence. It is different from the TestStand Sequence.
Why and what are you trying to import the data from .m file?
https://tmesystems.net/
(742 Views)
Can we also import .m file parameter in NI TestStand sequence?
(720 Views)
