NI TestStand
Teststand crashed when I try to open a sequence
Hello, in my team we have some sequences that uses some python scripts and teststand projects (3 and it has been developed with DQMH). It worked correctly but today that I wanted to open it ts got closed almost at the final part of the load bar.
Additionally, I've changed the adapter of labview runtime to development and the sequence was opened correctly.
I'm using TS 2020 64 bits and labview 2021 64 bits
Do you have some idea about what is happening? And some tips to avoid this kind of errors?
(682 Views)
So, TS crashes only when using LV RTE adapter. In this case, I would recommend narrowing down to the step causing the issue.
Try mass compiling the VIs and then start with skipping half the steps, try to load with RTE and slowly narrow down to the step(s) that cause the TS to crash.
Santhosh
Soliton Technologies
(662 Views)
Adding to Santhosh,
is it "just this particular" testprogram that's crashing TestStand or are there also others on this machine showing similar behaviour?
(641 Views)
