NI TestStand
How to make locals are as integer in teststand
 Hello Friends
            I m new to the Teststand .I have interest to learn Test stand and i know LabVIEW Somwhat.I have to initialise the locals as an integer and it pass to another locals its a real integer .It takes that value is in floating value.For example i m dividing one number ie 53/10.The result should 5.3 but i need only the integer as 5 only.But i get when i changed the format in locals but it pass to another real integer loclas it shows as 5.3 value.How to convert it.
Jayavel
(5,382 Views)
Accepted by Jai2K12
First TestStand only supports a single numeric data type and that is a float.
So you can't convert it to an integer in TestStand, but you can round the number to a whole number integer.
Round(53/10,0)
Number Round(Number number, Number option = 0)
This function rounds a number to an integer.
Parameter 1: The number to round.
Parameter 2: An optional parameter: how to round.
    Pass 0 to rounds towards zero (the default).
    Pass 1 to round away from zero.
    Pass 2 to round towards positive infinity.
    Pass 3 to round towards negative infinity.
    Pass 4 to round to the nearest integer. If the number is exactly between two numbers, rounds to the nearest even integer.
Returns:     The rounded number.
Omar
Omar
(5,379 Views)
Hello Omar
        Thanks for ur reply Omar.But i need one example its easy to understand the concept ..
Jayavel
(5,358 Views)
Hello Omar,
   I got the answer thanks for ut reply omar...
Jayavel
(5,356 Views)
