NI TestStand
How to modify ModelSupport.Seq
Hi Jiggawax,
I figured it was going to be a lot of work to add a new entry point.
Can you give me an example of how I can loop through the plugins to check to see if one is enabled or not and act on it?
Andy
Message 11 of 12
(381 Views)
The array you want to iterate through is Locals.ModelPluginConfiguration.Plugins.
This will give you the name of the plugin: Locals.ModelPluginConfiguration.Plugins.[Locals.x].Base.SequenceFileName (includes .seq)
And this will give you if it is enabled or not: Locals.ModelPluginConfiguration.Plugins[Locals.x].Base.Enabled
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 12 of 12
(377 Views)
