NI TestStand
How to modify TestStand Simple User Interface for Batch Model
I'm using Teststand Batch model (4 sockets).
I want to create user interface based on Simple User Interface Labview example.
First question that comes in is:
1. How can I display all 4 Execution View's of all 4 test sockets when teststand sequence file is running?
2. And if I want to have 4 boolean indicators on UI that show ehen each of Testsocket is running how can I do that?
(3,215 Views)
Hey Skoda3,
Actually there's no option to change sequence model implemented in Simple UI. But I've checked and you can achieve it by forcing Sequence property to use Batch Model from TS Development Editor (Edit -> Sequence File Properties -> Advanced -> Model Option -> Require Specific Model). After changing this option you'll be able to use Batch execution type. By default you've model options available in Full-Featured UIs.
Regarding your second question it may be a bi more complex. I think that this topic would be useful:
https://forums.ni.com/t5/NI-TestStand/Get-TestSocket-Index-in-Display-Execution-Callback/td-p/373336...
After all you'll need to check test sockets by using for example UI Messages.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3tWCAQ&l=en-US
Hope you'll find document above useful.
Cheers
(3,127 Views)
