NI TestStand
Variable Guidelines for Cleanup in TestStand
Some of my sequences can be very large and complex. One aspect which I struggle with involves opening relays and closing out of DAQme server. Depending on where a test fails, accounting for relays and handles can be challenging. I want to use FileGlobals (Boolean variable) for this purpose but our software architect discourages us from using them. What sequence guidelines should a TestStand user write to? Would that philosophy change for multiple threads?
Tony
(2,315 Views)
You can use engine callbacks to check for conditions then execute actions after test failure. You can learn about engine callbacks here. There's also this forum post where a user goes over the different engine callback types.
(2,289 Views)
