How to move Column position in the Teststand Report
I would like to change Column position in the report. For example, As you can see in the below figure, I want to move STATUS column to end of the column.
Can someone guide me How I can do this?
(458 Views)
You will have to modify the stylesheet in use for report generation
https://www.ni.com/docs/de-DE/bundle/teststand/page/customizing-xml-report-style-sheets.html
(453 Views)
I have read that link. but there is no related to my task what I want to do. Could you please share with me some perticular link if possible?
(446 Views)
I am not aware of any mor particular information on this. Yet there are some links in that article like adding coloumns which might be a starting point.
(434 Views)
