NI TestStand
How to open newer sequence file with previous version
is there a way to open/view a TS2022-file in TS2019 without using the option "Save as previous version"?
Is there a perhaps a trick/hack via manually modifying the the file with notepad?
or do i have to install a virtualBox with a demo version to do this?
(436 Views)
Accepted by OnlyOne
To guarantee proper file format; it would be best to open in 2022 and then Save-As 2019.
However, if the sequence file is in "xml" format, open the file with a text editor and change the version tags in the teststandfileheader element; but I would not guarantee the file will not have any other issues.
(402 Views)
