How to partly change text color in OutputMessage?
We could change OutputMessage color via "textColor" parameter. But it changes the whole message. Is there any way to paint one part of a message e.g. in red and the other in green? In the other words, is it possible to change color of a common string?
Max
(4,510 Views)
Accepted by maksya
Hi Max,
There is only one property for the text color and it applies to the entire output message.  I am pretty sure there is no way to subdivide the message into different colors.
Eric S.
AE Specialist | Global Support
(4,468 Views)
Thank you for the answer, Eric.
(4,454 Views)
This is a bad answer
(4,119 Views)
If you think it's an important missing feature, you might want to post it on the idea exchange: http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/idb-p/teststandideas
-Doug
(4,103 Views)
