NI TestStand
How to pass an external value to Test Stand?
Does any one know how to pass an external value to Test Stand?
Thank you.
(3,418 Views)
didn't snowpunter in this thread answer your question?
Regards
Ray Farmer
(3,413 Views)
No, he did not.
(3,411 Views)
Attached are the Call Executable tabs that I don't know how to use it.  Please advise
The limit for attachment is 4.  I got the last snapshot (Standard output/error), I set = ignore for now.
(3,405 Views)
in Standard Output/Error tab set Output Destination to Store in Variable/Property. The default location is Step.StdOutput.Text, you could change that to something like Locals.EggPlantStdOut. The stdout has to be copied to a variable in TestStand.
If it is not working I would try
1. Try it with an exe I know for sure is returning stdout.
2. Try your exe or a know good exe with the LabVIEW sysexec.vi to see how it is working
cc
(3,377 Views)
Thanks.  I am going to try your suggestion.
(3,374 Views)
