NI TestStand
Read or Write Parallel Model FileGlobals from Operator Interface
I understand how to access the fileglobals in sequential model by getting the sequence file's object reference and using GetValNumber but if I am using the parallel model, how do I access a specific socket's fileglobals?
(2,957 Views)
Directly accessing variables from the OI is usually frowned on as it couples the functionality of the OI to a particular sequence file. You should probably look into sending UI Messages from the sequence to the OI with the data that you're interested in.
CTA, CLA, MTFBWY
(2,945 Views)
