How to prevent TestStand OI from opening previously opened sequence files
I am using TestStand 2014. In my developer interface the previously opened sequence file does not open on startup, but in the operator interface it does. How can I change this from happening?
(2,425 Views)
Usually near the beginning of the OI code there is some ApplicationManager.ReloadSequenceFilesOnStart method.  You need to remove it or set it to 0.
http://zone.ni.com/reference/en-XX/help/370052N-01/tsuiref/reftopics/applicationmgr_reloadsequencefi...
If you let me know specifically which OI you are using I can point you to the location in the code.
jigg
CTA, CLA
testeract.com
(2,414 Views)
I found it, that was what I was looking for, thanks!
(2,388 Views)
