02-15-2010 05:03 AM
Hi everyone,
I'd like to know how to programmaticaly retrieve all the parameters that are defined in a sequenceCall step (in module window) :
* Parameter Name
* Type
* Value
I'm using TS API with Labwindows and i have a Step handle using :
TS_SequenceGetStep (gSeqObj, &errorInfo, iIndex, iStepGroup, &gStep);
I suppose i should get a module handle but i don't know what to do next with the module Handle
If someone could help me i would appreciate.
Thanks a lot !
02-15-2010 06:10 AM
I think this is the API that you are looking for. "Step.Module.AsSequenceCallModule.Prototype". You can use the handle of the step you get using TS_SequenceGetStep. This should give you the parameters container.
