NI TestStand
StationGlobal.ini file corrupted
in Teststand 4.2 stationglobal.ini file has corrupted
how can i get new ini file
(4,101 Views)
Accepted by topic author Teststand4.2 ini
If you just want to start over again with a clean verison of the station globals file, just delete or rename it. TestStand will recreate this file at startup if it does not exist.
If you would like for us to investigate how the file got corrupted, please provide the file and as much information as possible for everything that was done right before it got into this state.
Hope this helps,
-Doug
(4,090 Views)
hi
now new stationglobals.ini has been generated and we are getting error. that error has attached here.
(4,073 Views)
That is because you now have a default StationGlobals and TSVP is not a default StationGlobals.
You will need to add this and another StationGlobals that you system needs which isn't part of the default file.
Regards
Ray Farmer
Regards
Ray Farmer
(4,062 Views)
