07-07-2008 04:30 AM
07-08-2008 03:44 AM
07-14-2008 08:24 AM
07-18-2008 02:12 PM
Hi OnlyOne,
Dont know if you have sorted this problem out yet.
But if you haven't, In you lookup strings you will need to remove the "StationGlobal." from the string because you already have a reference from the StationGlobals.
You only use the full string as in you JPG when you use the SequenceContext reference.
Regards
Ray
07-22-2008 10:16 AM
07-22-2008 01:33 PM
Glad to hear you have sorted your problem out.
You are right about the SequenceContext. Had another look at the JPG you attached and saw the SequenceContext reference.
It was the attached VI that made me suggest removing the StationGlobals from the string as this has an Engine.Globals api call which would of returned a StationGlobals reference. I had assumed the VI was the one being used in the JPG without really studying the picture.
Regards
Ray
