NI TestStand
How to replace StepTypes over a hole SequnceFile
I have to update a StepType in some SequenceFiles.
Lets say there is type "User1" and it should be replaced with type "User2"
I found no suitable Teststand solution.
I opened the .seq file with Visual Studio and did a serach and replace over the hole file.
This is working well but i have to use VS !
Is anybody there knowing to solve this in TS ?
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,643 Views)
Accepted by j_dodek
Hi Juergen,
Can you not use the Find and Replace in the Edit Menu
there is and option the replace all instances.
  • Apply Replacements in Types to Type Instances—Enable this option if you want the Replace operation to update all instances of a type when a Replace is done on the value of a type property. Normally, changes to the value of a type property do not affect existing instances of a type.
    Regards
    Ray
    Regards
    Ray Farmer
    (3,641 Views)
    Hi Ray,
    Thanks for your answer. You are right!
    I tried the F/R in the edit menu before i post this, but i found only one hit,
    so i assumed this bad.
    When enabling the flag, it will only change the step name in StepTypes's view panel
    and all settings in the will refer to the old one.....
    ...But ! Now loading a file with desired Type will cause a confict (of course!)
    sloving conflict to this file will update my desired file!
    I think this is suitable and better than using VC
    Juergen
    --Signature--
    (3,628 Views)
