NI TestStand
How to reset an array to a default value?
i have a 2D array type text that should be set to a special value.
Dimension is [5][50] where the 5 is the MyIndex parameter of the socket in the BatchModel.
Currently i am doing this in a for loop that loops 50 times for each socket and in the loop i set the array to the value.
StationGlobals[MyIndex][Counter] = "value".
Is there any faster way to do this?
Thx
(4,661 Views)
Accepted by OnlyOne
Sure, you can use the following:
SetElements(Locals.MyArray,5)
That expression will assign every element of Locals.MyArray to the number 5. If you want, you can specify an optional parameter to assign the value to only part of the array.
(4,653 Views)
