How to save stationglobals to disk in Labview
Hi, Can someone suggest me how to save the stationglobal values to the disk when my vi is running? I am updating the stationglobal by calling set property TS API in my vi. But when i quit the TestStand and open it again the old stationglobal values are still there and not the new one. What should i do to update the stationglobal values? If anyone has any sample vi please provide me.
Thanks in advance,
Jeyan
(3,850 Views)
Accepted by Jeyan
Try this. You don't mention the version of LabVIEW you are using so I saved it to 8.0.
(3,842 Views)
There's an even easier way that doesn't involve any reference other than the engine.  You can call Engine.CommitGlobalsToDisk.
Also, I did a search on ni.com for "Save Global Variables TestStand" and found a KB describing this information: http://digital.ni.com/public.nsf/allkb/1A3C3AC9667F9C0886256C5300691822?OpenDocument
Josh W.
Certified TestStand Architect
Formerly blue
(3,823 Views)
Dennis,
        Thanks for your help. I could update the stationglobal now when my vi is running.
Jeyan
(3,812 Views)
