NI TestStand
How to search through an Array of Containers
Hello
Looking to search through an array of containers, meaning going through each index and then searching inside the container for the specified value
I'm aware of TestStands "Contains" function but that does not seem to look inside containers that are inside an array
So for example using the image above, i want to look in the "TESTING" array, then go through each container looking for the string value of "FindMe"
is this possible and how can this be achieved?
(1,110 Views)
I am using Teststand 2022
(1,070 Views)
One option is just a For Each loop on your array. Then have an if statement in the for each for the string comparison. If it matches use a break step since you have found what you want.
(1,044 Views)
