NI TestStand
Rename TestStand project (tsproj.tpj) file
It appears renaming a TS project file acceptable from the IDE but NOT acceptable when the named is changed from file explorer.  There is no method to relink the tsproj.tpj with the source sequence files.
I only method I see is to start by renaming your original tsproj file using file explorer, from the IDE delete the original TSProj file.  Create a new tsproj file, adding your project members.  If I rename a TSProj file in the IDE it should rename the file, looking from file explorer.
Message 1 of 1
(655 Views)
