How to set FileWritingFormat -> python
Hello Community,
I am using TestStand 2017 and the ActiveX API for
programming in Python.
The goal is to load a sequence file and change its format (mostly binary) to xml. so far, I have found the following:
engine =win32com.client.Dispatch("TestStand.Engine")
seqFile = engine.GetSequenceFile("file.seq")
xmlFile = seqFile.AsPropertyObjectFile.FileWritingFormat(3)
The following error occur:
AttributeError: 'function' object has no attribute 'FileWritingFormat'.
The 'FileWritingFormat' method can be used in the TestStand GUI, but why doesn't it work when using the ActiveX?
Thank you in advance 🙏
(2,296 Views)
Accepted by Leonard_007
You want to set a property, so this should be an assignment rather than a method call
I guess
seqFile.AsPropertyObjectFile.FileWritingFormat = 3
should do what you want to
(2,269 Views)
Hello Oli,
thank you very much, that works fine. However, a ' PropertyObjects were not released' error occurs. I have executed the following to close the engine after the API:
engine.UnloadAllModules()
engine.ReleaseSequenceFileEx(seq_file, 0x0)
seq_file = None
engine.ShutDown(True)# someone suggested to not use, it doesn’t make any difference
I found a solution on this page, however only the cumbersome way via the GUI works for me. There under Debug-Options you can uncheck 'Report Object Leaks ... '. Then everything works. But, it is only the dialog window is not shown, the error still remains.
Thanks again. 🙏
(2,241 Views)
Simply put:
each object created has to be released again. In my experience, it's best to have the release sequence just opposite to the sequence in which you instantiate objects.
I am usually working with the API in TestSatnd itself, so I don't really know what it exactly looks like in Python.
Is it possible you are opening further object refences?
I am shutting down the engine every time, since I consider this a good practice
(2,231 Views)
Good morning, Oli,
thank you for the hint. The code flow in Python is very similar to the one in TestStand. Apparently, you have to execute following when closing:
Engine.ReleaseSequenceFileEx(sequence_file, 0x4)
Engine.UnloadAllModules()
sequence_file = None
Engine.ShutDown(True)
Then the release leak error doesn't come anymore 🙂
(2,175 Views)
Good Job! Thanks for sharing your findings 😊
(2,166 Views)
