NI TestStand
How to set error-cluster in postexpression?
i created a c#-driver that returns a 0 for pass or -1 for fail in all functions "int MyFunction()".
Now i am using this functions for teststeps.
Question is: How can i use this returnvalue to set the error-cluster?
So that a -1 creates an error.
I think this can be done in the post-expression somehow.
How do i put a
if (returnvalue == -1)
Result.Error.Code = 10100
Result.Error.Msg = "Error occured"
Result.Error.Occured = True
Thanks for help
(4,363 Views)
Accepted by OnlyOne
Hi OnlyOne,
Check out this Example (saved to TS4.0)
The trick is done by using a conditional and literal breakets.
Locals.nReturnValue == -1 ? {Step.Result.Error.Code = 10100,Step.Result.Error.Msg="Error occured", Step.Result.Error.Occurred = True } : {}
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,355 Views)
Exactly what i was looking for.
Thx1!eleven
(4,349 Views)
