NI TestStand
How to set position of Call Executable Window
I have Parallel model with 8 test sockets. Each of the test sockets calls .exe program that opens in the top-right cornet.
How can I call executables so that each of the .exe program windows will be opened on different location so that I will be able to see all .exe windows in my screen?
(3,641 Views)
Accepted by Skoda3
One possible solution is to get a program such as Cmdow. This program can move and resize a command window.
Then, create a .bat that calls Cmdow and your executable.
Pulido Technologies LLC
(3,625 Views)
Thank You, this was the solution.
I have created .bat file and it works ok for me.
moveWindows.bat file is:
cd C:\Users\me\CmdowFolder\Bin\Release  :: location where Cmdow.exe is saved (no installation needed)
cmdow "First Window To Move" /MOV 1 370 :: arguments for move command -> /MOV top left
cmdow "Second Window To Move" /MOV 365 370
cmdow "Third Window To Move" /MOV 730 370
cmdow "Fourth WIndow To Move" /MOV 1095 370
(3,614 Views)
