How to set the SequenceFile/Sequence from without a TS control?
We would like to make sure that the user does not run an incorrect sequence.  How can I pass the sequence file path to TS from the OI without using the Teststand dropdown?  What about the Sequence control?  Can I just ignore/hide that one too?
Thanks!
(3,353 Views)
OK, I found the call in the ApplicationMgr; but when do I call it?  Right now the SimpleUI is still using the drop-down to overwrite my choice.
I suppose I will have to disconnect the dropdown, no?  I'll give that a shot...
(3,352 Views)
Looks like "Disconnect" is not an option.  Hmmm.
Implications:
1) This means I cannot easily edit the example code to NOT connect this (I will have to create a disable structure around the whole "Stack" of connections in the subroutine).
2) I can't build an interface where I cannect and reconnect other elements, can I?
(3,351 Views)
Accepted by Jed_Davidow
Hi Jed,
Take a look at this example and see if it helps:
Hard Code a Sequence Path in the TestStand Simple OI
Peter Rifken - Field Engineer & Business Manager
Boston / North New England & Maine
(3,338 Views)
