NI TestStand
How to unload a .NET module during runtime (programmatically)
I am working on a C# program running in a .NET module in TestStand, so I have Visual Studio and TestStand open. I change/compile my code in Visual Studio and then I try to run my sequence, which calls a method in my C# program.
I have the very annoying problem of needing to do File > Unload All Modules, after every time I run my sequence, or else I can't recompile my C# code. I get this error in Visual Studio:
Unable to copy file "obj\Debug\WindowsFormsApp1.exe" to "bin\Debug\WindowsFormsApp1.exe". The process cannot access the file 'bin\Debug\WindowsFormsApp1.exe' because it is being used by another process.
How do I unload my .exe (from the .NET modules) at the end of my sequence? I try calling RunState.Engine.UnloadAllModules() in a Statement in my sequence, but it doesn't work.
I have attached a dead simple example with a .seq file and a C# file.
My problem is compounded by a project I'm working on that has a separate sequence running constantly in the background, in addition to my custom sequence. So when I do File > Unload All Modules, I have to rerun that separate sequence before I can run my custom sequence.
(2,430 Views)
Accepted by topic author Dana517
Have you seen this: https://www.ni.com/en/support/documentation/supplemental/19/unloading--net-assemblies-in-teststand.h...?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,380 Views)
That link did help. The last paragraph mentioned that the Sequence Analyzer can prevent .NET modules from being unloaded.
I went to Debug > Sequence Analyzer > Sequence Analyzer Options... -- and in the dialog, I unchecked "Analyze File Before Executing". After that, I stopped needing to click Unload All Modules.
(2,319 Views)
