NI TestStand
Sending UI message from dotnet dll
I have created a UI and a sequence file with DotNet dll. In order to update my UI i start a measurement in my DotNet dll and in the next sequence step i sent the RunState.PreviousStep.Result.Numeric via PostUIMessageEx to my UI.  So, i need 2 sequence steps to do a measurment and update the UI.
Is it possible to send the UI message with the measurement result directly from my DotNet dll to the UI ?
If possible please send me an example
Thanks in advance.
(1,285 Views)
Check this link, it might be helpful for You.
Regards.
(1,133 Views)
