NI TestStand
Package Installer and Patch Deployments
Using the TestStand 2019 Deployment Utility, I created a Package-Based Distribution > Package Installer. This worked fine; I got an installer that installed NIPM, runtime engines, drivers, and my TestStand files.
Since then, I made some changes to some LabVIEW VIs and the TestStand Sequence file. What is the recommended way to create the equivalent of a "Patch Deployment" for a Package-Based Distribution?
  • If I select "Patch Deployment", it generates a full-blown installer anyway.
  • If I select Package-Based Distribution > Single Package, that seems to give me what I want: A small .nipkg package that can be installed on top of the original full installation. However, this is still registered as a "Full Deployment".
Certified LabVIEW Developer
(941 Views)
There are several deployment ways, check this link, there is enough information and links, for sure You will find best option for Your case.
Regards.
(906 Views)
