How to use 2 array to plot a XY graph
Hello~
I use for loop in teststand2014 to get 2 arraies with same loop indicator as attachment(Vi_array=input voltage, Po_array= output power).
how can i build a XY graph with these 2 arraies, Vi_array as X and Po_array as Y?
thanks!
(6,147 Views)
Accepted by johnnnywang
You can create a 2 dimensional array out of the 2 arrays you mentioned and use the "DataLayout" and "DataOrientation" attributess for the new array you generated. Please have a look at the attached sequence file created using TestStand 2010 version to know how it can be done. I have tested the graphs in XML reports.
With Best Regards,
Srivinayaka
(6,126 Views)
hello,
     I've tried with this sample with TS2014, it works well.
but i don't know why i get 2 seperate curve in TS2013, attached the graph and the seq file. please help to check again. thank you very much!
(5,853 Views)
excuse me, I've add atributs of the array as attachment, but curve still in 2
(5,843 Views)
Hi, I try to use the way you provided but I am also getting curves with many lines. Do you have any ideas about this?
(4,893 Views)
