How to use Call executable to run a ping command?
i am using TestStand 2014 and want to use the Call Executable to open cmd.exe and run ping 127.0.0.1
For this i currently inserted C:\Windows\system32\cmd.exe at File Pathname and "ping 127.0.0.1" at Argument Expression.
But this only opens the command-window when executing the step.
How do i do it correct?
Edit.
Solved: Only the parameter /r was missing in Argument Expression before the Ping command.
(6,261 Views)
Accepted by OnlyOne
Hi
         Ping is an independent executable tool. Its not an argument. The executable is under "C:\Windows\system32\PING.exe". Configure the step to call Ping.exe and give the arguments as "127.0.0.1".
You can use the sequence attached.
Sathish S
(6,176 Views)
