How to use XML file to Build the TestStand Sequence
There is a TestStand example name "Building a Sequence Using API - XML.seq". But the example is too simple. How  to create a step calling LabVIEW vi? It's better if share some help files.
(3,015 Views)
Accepted by 阿辉001
Hi 001,
maybe this thread contains what you're looking for
https://forums.ni.com/t5/NI-TestStand/Create-a-LabVIEW-Step-dynamically/td-p/976702?profile.language...
Best regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(2,998 Views)
Hi j_dodek,
It's different. I want to generate a XML or INI file. Then Run a teststand sequence which can analysis the file and execute.
(2,961 Views)
did you open the CreateSeqFileReZIP.zip ?
Best regards
Juergen
--Signature--
(2,950 Views)
