I am currently using Teststand 2010, I have a sequence in the Cleanupk the "terminate" button. I have tried all the precondition that I know and still unable to skip the step whenever the sequence is terminated. Any help would be greatly appreciated.
I am currently using Teststand 2010, I have a Step sequence in the Cleanup and I want to skip that step whenever a user click the "Terminate" button. I have tried all the precondition that I know, but still unable to skip the step. Is there any precondition/Post Action I could use to skip the step when I terminate the sequnce module? Any help would be greatly appreciated please see picture below.
WJ
(4,268 Views)
Accepted by justin1269
Use a statement step at the beginning of your Cleanup step group.  In it put:
RunState.Execution.GetStates(LocalsExecutionRunState, Locals.TerminationState)
You will have to create both the locals as numbers.
Then in your precondition you can say:
Locals.TerminationState == 1
Refer to the TestStand help for more information on that method and to look at the different state meanings:
ExecutionTerminationStates Enumeration
The Execution.GetStates method returns one of these values to indicate whether the execution is terminating. If the execution is terminating, these values indicate how it is terminating.
ExecTermState_Aborting–(Value: 4) TestStand is aborting the running execution.
ExecTermState_KillingThreads–(Value: 5) TestStand is ending the threads in the execution.
ExecTermState_Normal–(Value: 1) The execution is not terminating.
ExecTermState_Terminating–(Value: 2) TestStand is terminating the running execution.
ExecTermState_TerminatingInteractive–(Value: 3) TestStand is terminating the running interactive execution.
Hope this helps,
jigg
CTA, CLA
testeract.com
(4,250 Views)
Here is an expression you can use as the step precondition without the need to make other changes:
#NoValidation,  // suppress the analyzer error for the non-existence of the temporary variable
Locals.SetValNumber("_terminationState", PropOption_InsertIfMissing, 0), // create a temporary variable
RunState.Execution.GetStates(0, Locals._terminationState ),  // get the termination state
(Locals._terminationState == ExecTermState_Terminating && ( Locals.DeleteSubProperty("_terminationState", PropOption_NoOptions), True))  ?  False : True
(4,230 Views)
Thank you for your help, I was able to resolve the issue
WJ
(4,221 Views)
Thank you for your help!
WJ
(4,219 Views)
