NI TestStand
I can only open the seq. vi. No other vis will open.(vis running)
I can open a seq vi but when I try to edit another vi in it,  the vi is already running (no edit). If I uncheck the options Reserve loaded vis for executing then I can edit all vis. This option is located in LabView Adaptor Configuration.
(3,095 Views)
Have you tried "Unload all modules"???
(3,092 Views)
Use the edit button from the either menu or from the Edit Labview VI dialog rather than just opening the VI. This will release the VI so that you can edit it and any sub VI's.
Regards
Ray Farmer
Regards
Ray Farmer
(3,083 Views)
