NI TestStand
In the Full OI, is it possible to select only certain sequence steps to run?
Trying to create a diagnostic mode. How can I select only certain steps to run and keep track of which ones have passed/failed?
(2,910 Views)
If you highlight the steps, you will then beable to use the "Run Selected Step" menu item.
In your Operator Interface or even in you SequenceFile, you can make use of the property RunState.InitialSelection.SelectedSteps which is an array of containers, the container being a Step.
Hope this helps you get started.
Regards
Ray Farmer
Regards
Ray Farmer
(2,906 Views)
