NI TestStand
I cant edit a steps code any more
I created a sequence in teststand and have been messing with the user manager and now when I right cleck on the specific step in teh sequence editor it doesnt allow me to edit code anymore.  I then oipened up an example and it did the same. I checked the user manager and it has the priveleges set to grant all so I am stuck.  If I add a new step to the sequence and insert it and then go to the specify module tab, it doesnt allow me to create a VI either.  Appears to be a privelege thing or something...Help
(4,408 Views)
What is your LabVIEW adapter set to?
Is it set to Development Environment or is it set to Run Time Engine?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,383 Views)
Accepted by id
You hit th enail on the head.  It was set wrong in the dialog
(4,380 Views)
