NI TestStand
I get run time error in step Set Report in reportgen_xml sequence
I get run time error in step "Set Report" in reportgen_xml.seq. The error code is "Out of memory".
I don't know what to do.
I use BatchModel, I have 6 batch loops. The problem appears on the 3d loop. I have NI 3.5.
Help me!!!!!!
I send attachment (screen of error).
Message 1 of 14
(4,930 Views)
Hi Marta,
How much RAM do you have and how fast is your processor?  Depending on these, you could be receiving this error.  You could also try changing the below settings.
In the Configure menu, Report Options, select "Conserve Memory and only display latest result"
In the Configure menu, Model Options, select "Discard Results..." box.
Let me know if this helps out.
Message 2 of 14
(4,898 Views)
Hi Terry, thank you for your reply !
I don't know why - the option "Conserve Memory and Only Display Latest Results" - is not for change in my TestStand. I send you "print screen" in the attachment.
Message 3 of 14
(4,874 Views)
Those options are not available for XML reporting.  It might be that the result list is too large and runs out of memory.  For the loop that it throws the error in, what exactly is that loop doing?  I will try to reproduce the error.
Message 4 of 14
(4,858 Views)
Hi Terry,
each loop does the same tests,
my computer is Pentium(4) 4 CPU 2.66 GHz 2.68 GHz, 504 MB of RAM.
When the problem will occure again I'll send you xml report .
Thank you for your help !
Message 5 of 14
(4,840 Views)
Can you briefly explain exactly what is happening in the loop?  This way I can try to duplicate your test.
Message 6 of 14
(4,812 Views)
Hi Terry, it happened again 😞
Actually I see that the problem appeares in the same subsequence of my sequence. In that  subsequence I have approximately 25 numeric steps, 6 of them are on skip now.
The problem appeares suddenly after many batch loops.  I have the message "Error, Parameter new value: Out of memory. [Error code -17000, out of memory].
After that on next loop I see it runs and writes reports for others subsequences and steps, but on the "problem subsequence" again I get message "Out of memory"...
At the one of the problem loops I saw other message "An error occured calling 'Process One Result' in ITSO FlyReportGen of TestStand on-the-Fly-Report-Generator. Out of memory. Source: TSOTFRG  [Error Code: -17000, Out of memory].
I use "Discard Results or Disable Results " enable option in the ModelOptions. But without success. Is this a problem of TestStand or may be is this the special problem of my subsequence or any step in that subsequence?
Message 7 of 14
(4,787 Views)
Hi Marta,
Can you post your sequence or an example sequence of what you are doing that also causes this error?  I haven't been able to duplicate this error yet.
Message 8 of 14
(4,770 Views)
Hi, Terry. I analyzed this error is occured only when I use xml - report. In case of html report it isn't occured.
Anyway I send you my sequence. Actually the problems is usually happened on the DVMD Errors Monitoring (DVMD Test sequence). But I tried to run many loops with html report option and I didn't get this error.
Regards.
Message 9 of 14
(4,761 Views)
There might be a couple of issues that might be causing this.  An XML report has more overhead than an HTML report and your resultlist could becoming to large and therefore, running out of memory.  I am currently trying to test this out to verify what exactly is causing your error.  I will post my result, when I narrow this down.
Message 10 of 14
(4,732 Views)
