NI TestStand
I get run time error in step Set Report in reportgen_xml sequence
Ok, thank you.
Message 11 of 14
(1,344 Views)
I tested this out and came across the same results.  The problem is that XML reporting has a lot of overhead, which is caused by how XML is generated.  Because of your sequence size, the best solution is to use HTML or Text reporting.  These have less overhead and should not cause the error.
Let me know if you have any questions.
Message 12 of 14
(1,327 Views)
Or maybe you could re-organise your sequence file, maybe split into multiple sequence file and / or unload sequences that are not used in your main loop section.
Regards
Ray Farmer
Regards
Ray Farmer
Message 13 of 14
(1,320 Views)
Thank you very much for your help ! Probably I can use html reporting instead xml report.
Message 14 of 14
(1,306 Views)
