It could be you have two problems.
Your original problem may have been due to a corrupted database file.
The second problem is probably due to the uninstalling and re-installing TestStand and patch.
I would suggest:
1) remove the sub folder from \Components\User folder. Copy the folders from the \Components\NI folder to the \User folder. Launch TestStand and try out the Example for Database use. If that works then check out your origin problem.
If it fails then -
2) I would suggest uninstalling teststand. Rebooting your PC. Then make sure all traces of it are removed from your hard drive. Make sure you back up any data in the TestStand\...\User folders.
Then reinstall TestStand and patch.
Then using one of the examples for database. See if everything w
orks. Follow the example in the Database Components PDF file - Example Data Link and Result Table For Microsoft Access.
Good Luck
Ray Farmer
Regards
Ray Farmer
